1968 Ford F100
Had numerous problems with ignition not shutting off and starter still engaged.shutting off by stalling the motor with manual shift(*popping clutch),then the motor would start then not shut off at key... There is alot of scenarios for this but the easiest one is after you replace the solenoid, is to hook a ground wire from battery ground and other end behind solenoid to the body and that should do it .ford id rocks
Ignition does not shut off
- jades addiction
300 six banger 3 speed on the tree with 33,000 orig. miles Next was to get it painted and restored ,3 years later a new motor f(1986 302 5.0 HO ) parts from a 1971 mustang to a 1965 mustang .. huge aluminum radiator to keep at 160 degrees, bored 60 over, cam 750cfm edelbrock with a matching performer, roller rockers on new edelbrock 201 aluminum heads, and mustang headers,HEI distributor, Just put on a power disc brake conversion kit 11 3/4 inch rotors from MPBrakes ,brings a whole new meaning stopping on a dime!Got rear leaf springs ,dropped 2.5 inches and she cruises so much nicer!
