Hello,
Can anyone help on recommending a site for a complete wiring harness for the engine area. I would like to rewire my 1969 Ford pickup F100 360 cu in.
any help would be greatly appreciated.
Thank you in advance.
Complete wire harness for 1969 F100
- tbone6
Re: Complete wire harness for 1969 F100
If you are just wanting the engine harness, I have no recommendations. If you want to go all out, I would suggest Painless, as they make specific harnesses for our trucks and are of highest quality, IMO. I have installed the KWIKWIRE harness and found it to be just okay. Good luck!
t6
1972 F100
1972 F100
Do you want just the wiring on the motor, or do you want the harnesses on the fenders too? The link below is for a Mustang, but the harness is the same for your truck. They also sell an alternator harness, but I'm not sure if they are the same as the truck's version. The painless kit is also a good way to go. PN: 10117(no switches) and 10118(with switches).
http://www.dallasmustang.com/mustang-pa ... K-ALL/4514
http://www.dallasmustang.com/mustang-pa ... meter/4927
- HIO Silver
Complete Ford truck-specific wiring systems are available from Centech.com.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- HIO Silver
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- HIO Silver
Complete Ford truck specific wiring systems are available from Centech.com.
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- HIO Silver
68 Mustang
65 Mustang
68 Mustang
65 Mustang
