no rear braake lights
fuses under dash good, bulbs good, new switch under brake petal replaced. i just dont know, anything to do with new ignition switch i just replaced or disconnected turn signal unit?
- bluef250
Re: no rear braake lights
Check ground on the brake lights. Pull light assembly and clean up all the connections.
- Nitekruizer
Is the pedal pushing the switch in far enough?sacramento_ford wrote: new switch under brake petal replaced.
Could also be a defective switch. Maybe try unplugging the switch and checking it with an ohmmeter while pushing the switch manually.
- flyboy2610
It could be the turn signal switch. On these trucks, the turn signals are actually your brake lights flashing on and off.
Red Green
you'd better be right.
Red Green
