Need fuse box map for 1979 Ford
rascal4now
Post by rascal4now »
Friends of mine have a 1979 Ford motor home. It is an 8 cyl and not loaded. Just basic. Considered a 5 ton. They are having a heck of a time with their signal lights and rear lights and clearance lights. We want to check and make sure that the fuses in the box are correct. However, it isn't possible to read the fuse box due to the age. The writing is all worn off. Is there anyone that knows where I can get a picture/explanation of what fuse SHOULD be in the fuse box please?
Thanks in advance
fordamericana
Re: Need fuse box map for 1979 Ford
Post by fordamericana »
http://fordification.net/tech/wiring.htm
Always try Google image search too, sometimes it will yield picture of actual fuse blocks with color, and wiring diagrams as well.
I likes My FE I does...
rascal4now
Thank you. I'll check it out
Allow me ... http://www.google.com/search?q=fuse+blo ... 66&bih=681 They always give you too many to choose from and not always fit the application but maybe you'll find what you're looking for amongst 'em.
