side markers
- Mancar1
side markers
Changing the side marker lights on the 68 CS. The old ones have the two wires . The new ones just the hot, and the marker mounting screw is the ground. I am thinking that I use the hot and tape off the ground wire, or hook it to the mounting screw. My thinker has a lot of years on it. Some things I know I have done in years gone by just are not as clear as they used to be.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- Nitekruizer
Re: side markers
I'm assuming that these are just single filament bulbs like a 194 or something similar. In which case I would just try one of the lights with the ground wire not connected and if it doesn't light up, try it with the ground wire attached to the mounting screw.
- Mancar1
Re: side markers
Thanks for the reply. Yup I will put hot to the single wire and ground is the marker body to truck body.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
