I found this: Which had 4 hot wires (only one fused!) running to the rear bumper area. It appears that the PO either added trailer wiring or had something else back there, but the bed is unmolested and doesn't appear to have had a camper or anything other than a bumper hitch. Plus I'm stumped as to why there would be FOUR 12V unfused wires needed for anything to begin with. They were not hooked up to lights on the truck (but there are some other wires tapped in for trailer lights unrelated to these), literally just constant 12V off the hot side of the starter relay and the little box I show in the pic above - Is that box a circuit breaker or just a terminal expansion? Both terminals are hot all the time.
In other unrelated news: I also found an orange wire under the dash above the fuse panel, with a male bullet connector (looks factory) that doesn't have any power regardless of key, and what appears to be the same wire in front of the firewall as a female bullet connector. Neither end is hooked up to anything (thus the lack of power
And in that same pic there was a strange connector with black/red? wires that was jumpered (bottom arrow in pic above)...no idea what that's from either and I've scoured the wiring diagrams. It almost seems like it is for the reverse switch...but the lights work and I can't understand why it would be jumpered?
Any ideas oh wise Bumpmasters?
