dim headlight?
dim headlight?
I've changed the light and it is still dim, the other is fine. wondering if it is a grounding issue or the socket? I'm sure everyone has had this issue before hoping for a quick way to check or fix. thanks
Re: dim headlight?
check your ground, maybe even run a new one. had the same problem, new ground wire fixed it
- BobbyFord
Re: dim headlight?
Bad ground. Guaranteed. Prolly just need to clean the terminals.
- basketcase0302
Re: dim headlight?
What kind of bulb did you install? Was it a halogen bulb?danthony on Wed Jan 09, 2013 8:36 pm
