temp guage
19674x4
Post by 19674x4 »
well, i drilled the hole and it is a smidge to small, so i got to get a bigger bit
My Photo Album
2012 Cummins-the luxury Tow Pig
1967 F-250 highboy 352, np435(((((((sold))))))))) My first true love
1968 F100 SWB. 360, np-435, flatbed, currently acting as a hornest nest and bee hive.
1971 F-100 4x4 Step-side. 360, np-435, 70k origional miles- needs allot of love.
Joe Kriston
re: temp guage
Post by Joe Kriston »
Ok,as long as the topic is temp gauges,I have a question...Where does the needle usually sit on yours when you're at normal operating temperature?...On both my trucks,the needle always seems to want to plant itself on the warm side of the normal range....
The camper special I drove to Chicago in cold weather and a new 195'(I think) thermostat would warm up to just before the hot indicater and stayed there the whole trip....The needle on my Explorer with the air on in 110' heat operates at about the same spot on the temp gauge :hmm: ....I'm wondering how accurate these temp gauges are....
This is the point...I'm....talking about everybody! I'm talking about form! I'm talking about content! I'm talking about interrelationships! I'm talking about God, the devil, hell, heaven!!!! Do you understand???? Finally!!!!
AmericanMuscle67
Post by AmericanMuscle67 »
mine sits in the low side of normal
Ace
(Past)
1967 F-250 Holly Green 390/C6 (Parted out)
1967 F-100 Holly Green. 352 auto. (totalled)
1979 F-150 Brwn 300 I-6 4speed (SOLD)
(Present)
1967 F-250 Camper Special. Lunar Green 390/C6, A/C ready.
2005 Dodge Ram 1500 Reg. Cab LWB
joe that doesn't sound right.
Jake11
re: temp guage
Post by Jake11 »
If just the temp guage reads too high all the time, you can put a 10 or
15 or 20 Ohm resistor in the sender wire. Will make the guage read a
little lower.
Joe Kriston
re: temp guage
I forgot I asked this question here...I guess it wouldn't hurt to hook up a gauge that gives an actual temperature reading...I just wondered how accurate the in-dash gauges were....Neither of my Fords in different conditions seemed to run on the cooler side of the normal range....
Jake11
re: temp guage
Post by Jake11 »
IMO, the needle should be a little less than middle at 180deg. You can
can adjust it using resistors. I got mine from Radio Shack.
Joe Kriston
re: temp guage
Jake,if you do that will it screw up the gauge reading if your truck is actually overheating?
Jake11
re: temp guage
Post by Jake11 »
No, it still works normally. You just changed where the needle points
to at normal operating temperature. It's best to verify the temp with a
thermomiter in the radiator coolant to make sure the guage is accurate
before you trust it. I have found most read high by default. All you really
want to do, is have it read in the middle of the scale, not start at the end
when the motor is at normal temp. Then you have a baseline of where
it reads.
71-F-250SC-72-F-250C
re: temp guage
Post by 71-F-250SC-72-F-250C »
I forgot about this thread. Well thats good about the alt gauge, that means all my guages work now. :thup:
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic. :)
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
