Alternator questions
jrreed1634
Post by jrreed1634 »
I am looking for a new alternator and found this one at Summit.
http://www.summitracing.com/parts/TFF-7068ABULL/
Can someone tell me if this will work? It says it has a GM case with Ford mounting. i am planning on using an EZ wiring harness. I think the 100 amp will be enough for me. Everything is stock except I am planning on a new stereo system.
Finally, somehow I lost the upper alternator bracket. The part number page has different options for my 352. LMC has one but it is for a 302. Anyone know of somewhere I can buy one for the 352?
Racer Z
Re: Alternator questions
Post by Racer Z »
It should work just fine. The difference between a Ford and GM alternator is the voltage regulator. Ford uses an external while GM uses an internal. The GM provides for a cleaner look as there are less wires and no regulator on the radiator support.
I've never bought or used an "EZ wiring harness". See if they have an optional one that supports the GM style alternator.
