tail light and front signal problem
I'm having a weird problem with my back driver side and front passenger signal lights...m front signal comes on and off randomly ..if I hit the fender with my fist it will come on and go back off..I take it that its a nad ground maybe? My tail lights work but when I press the brake the driver side goes out..I put new bulbs in all around and it didn't cure my problem...any ideas?
- 70_F100
Re: tail light and front signal problem
Sounds like bad grounds on both ends.
That's not an oil leak
- basketcase0302
My 71' has ground wires from the front light assemblies that are screwed onto the radiator support if memory serves me correctly. I'd also look at the ground strap on the front frame horn to radiator support, (it's by the DS bumper bolt hole) and make sure the rear tail light assembly is grounded good. Might want to look at the contacts on the light socket themselves real close also.
Thanks guys..any idea whete the tail lights are grounded
- basketcase0302
Please excuse me, few years since I've owned a Ford truck with a factory bed on it (flatbed owner).lead foot caveman on Sat Dec 31, 2011 10:39 pm
Thanks guys..any idea where the tail lights are grounded
It has to be somewhere here on the below diagram, maybe someone else can chime in here to help?
- 70_F100
IIRC, there isn't a separate ground wire for the taillights. They just ground through the mounting screws.
- basketcase0302
Thanks Richard! So the housing would need to be grounded good when screwed into the bed?
- 70_F100
Pretty sure that's right.basketcase0302 wrote:Thanks Richard! So the housing would need to be grounded good when screwed into the bed?
There are two screws that hold the housing to the bed, welded nuts on the back side of the hole. If everything is good and clean (pretty tough on a 40+ year-old truck
