Camper Special front side lights
- MaiTai
Are the front side lights for a 69 Camper Special supposed to blink with turn signal or are they just running lights with the headlights? Wondering if they are related to my fast blinking issue....
Re: Camper Special front side lights
they are a parkign light not a corning light. if you blinker is too fast you can change the flash can to a slower rate flasher can. i think the slow rate one for the blinker is a 442. the hazard flasher is a faster rate. flasher. and may be a 559. check the parts stores about the correct flasher numbers. i may have those numbers wrong. i dont have any here in front of me to look at anymore.
you know with the correct combination of flasher cans you can make you flasher look liek the cops flashers and blink really funny and super fast like thiers do.
- MaiTai
Ok - thanks for the info
- Mancar1
I have had that happen when the flasher is about ready to give out.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
i wonder if it is cross feeding when that happens.Mancar1 wrote:I have had that happen when the flasher is about ready to give out.
