Turn Signals
bewild
Turn Signals
Post by bewild »
Hi ,
I am having problems with my turn signals and wanted some advise.
1967 Ford F100
The problem:
The drivers rear and the passanger fron turn signals work only.
I have running lights and brake lights so it's not the bulbs.
Any ideas?
Thank you in advance
Brian
Re: Turn Signals
it could be many thigns. form a bad wire to a bad turn signal switch. you just have to start checking it out.
bewild
Re: Turn Signals
Post by bewild »
Thanks Fordman
I just wanted to check I have heard turn signal switch.
