lighting switch removal
r3vo_3vom
Post by r3vo_3vom »
Is there a trick to removing the lighting switch in these things :? . its kicking my butt :x
thanks in advance for the help.
:fr:
Matt
"I have as much authority as the Pope, I just don't have as many people who believe it." George Carlin
'68 F100 Ranger LWB 2wd 360ci C6
'75 Chevy 3/4 ton Flat Bed 350ci 4x4
'03 Yamaha Road Star Warrior 102ci
91Bear
Re: lighting switch removal
Post by 91Bear »
What exactly are you referring to? The headlight switch in the dash? If so, you have to remove the knob & bezel first. I used a flatblade screwdriver wrapped in masking tape so as not to scratch anything. Reach under the dash and feel around on top of the switch for a button. Push down on it and pull out the knob at the same time. Then, remove the bezel and the switch will unscrew from the dashboard.
r3vo_3vom
Post by r3vo_3vom »
thanks for the quick reply got it off and now im wiring it up
Matt
