Turn signal switch .... armature mounting
- neoxman
I did a search and looked at the diagrams but I can't tell if the armature for the turn signal switch screws into the plastic switch or if theres some other piece that it screws into.
Re: Turn signal switch .... armature mounting
what are you trying to do? replace the turn signal cam?
- neoxman
I don't have a turn signal switch assembly... didn't come with the truck. but the original rod/lever arm did. So on the column theres the hole but no place to screw in the rod. I need to buy the switch assembly but wanted to make sure there wasn't something else i was missing.
the turn signal arm screws right into the turn signal switch.
- neoxman
