Engine lifts
- Heathcliff68f100
Engine lifts
what do you guys do when you dont have one?
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
Re: Engine lifts
just before i got mine i was borrowing the nieghbors. before that all the large stuff went down to my dads place where he had a cherry picker. in between dads place and me borrowing and then getting my own. i have removed 4 cyls from cars piece by piece and a chain and pipe to get the block out. other ways are to use a tree and a ratcheting come along.
- Heathcliff68f100
Re: Engine lifts
well i gotta pull my 240 and i dont have a big enough tree and none of my friends have one i can borrow, what would you do?
Re: Engine lifts
you can rent them also. i forgot about that option. we have a equipment rental place that will let you rent cherry pickers. i did that once myself.
- hdpusher
Re: Engine lifts
1. Take three long pieces of water casings (pipe) chain the ends together so you can make them into a teepee. Place over what you would like to lift, place a come along in the chains and lift.
2. We have chained up the engine, placed a heavy pipe through the top of the chain above the fenders. The pipe needs to be long enough to stick out past both fenders so someone can grab each side. Take the tires off the vehicle set it on the frame. Now you can stand on blocks or if your tall enough and or the vehicle is low enough you pick up on the pipe and remove the engine. I does take alot of work but in a pinch it can work.
These are not the safest ways of doing things and you may cause more damage than you intend. Id really try to borrow or rent one first.
67 Chevy II 302 sbc
67 Ford F350 Motor home
68 Ford F100 long bed (Sold )
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
- BobbyFord
Re: Engine lifts
Just my here but when you improvise and "manufacture" tools to use in place of the proper tool it ALWAYS takes longer and greatly increases the chance of personal injury. It's always best and safest to use the correct tool for the job. You are better off renting a cherry picker.
Re: Engine lifts
there is no way i am that strong. well maybe fo the head and intake were off the 6cyl engine.hdpusher wrote:1. Take three long pieces of water casings (pipe) chain the ends together so you can make them into a teepee. Place over what you would like to lift, place a come along in the chains and lift.
- hdpusher
Re: Engine lifts
My bad fordman... I didn't explain that one correctly. You grab one side and someone grabs the other or have 4 guys two on each side.fordman wrote:there is no way i am that strong. well maybe fo the head and intake were off the 6cyl engine.hdpusher wrote:1. Take three long pieces of water casings (pipe) chain the ends together so you can make them into a teepee. Place over what you would like to lift, place a come along in the chains and lift.
67 Chevy II 302 sbc
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
Re: Engine lifts
We always used a re-inforced header beam int he garage and a come-along until we finally found an old chain hoist
Re: Engine lifts
i knew what yo umeant. i just dont think me and a helper could do it. mayeb. i did do a 4cyl similar to that myself though. i used a bar across the core support and the firewall and used the firewall as the piviot point. and picked the block up out of there myself. i then rolled it off of the core support to the ground and was able to pick it up kind of and move it into the garage.
- hdpusher
Re: Engine lifts
I think youd be surprised. The last one we did was a semi stripped down SBC and they are roughly 550 complete 4 of us managed to get it out fairly easy. A Ford 240 I6 prob weighs 400ish. The problem with the f100 would be getting it low enough to clear the core suport.fordman wrote:i knew what yo umeant. i just dont think me and a helper could do it. mayeb. i did do a 4cyl similar to that myself though. i used a bar across the core support and the firewall and used the firewall as the piviot point. and picked the block up out of there myself. i then rolled it off of the core support to the ground and was able to pick it up kind of and move it into the garage.
The only time we realy have done it is when a vehicle is found in the woods or in a field and we cant get any equipment in to remove the vehicle or the engine any other way.
67 Chevy II 302 sbc
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
Re: Engine lifts
you can also try craigslist for used ones too..
Re: Engine lifts
thats where i got mine from. it came with a engine leveler and a new cylinder. all for 100.00 it had original came from harbour frieght.mhobryan wrote:you can also try craigslist for used ones too..
Re: Engine lifts
in my younger,stronger,stupider and stoneder years my bro and i pulled a 302 out of a 68 cougar using method #2 - only with out removing the tires,just the hood...we also lifted a 351w into and out of the trunk of my old malibu by hand..( should seen the looks on the machine shop guy's faces)
so glad i smartened up and started renting & eventually bought a crane
Re: Engine lifts
Just use your backhoe!
