Way off topic: need fuse location for 97' E-150
basketcase0302
Post by basketcase0302 »
Hey guys,
Can anyone point me toward information on the interior fuse box fuse location(s) for a 1997 E-150 series van. I know it would be on the fuse box cover usually, but some rocket scientist decided to throw away the cover. :hw:
A quick google search didn't turn up much...
Thanks in advance.
Re: Way off topic: need fuse location for 97' E-150
on my 93 F150 8 is the brake lights and speedometer. what one do you need to find?
Thunderfoot
Post by Thunderfoot »
Here you go!
Go to this page http://www.motorcraftservice.com/vdirs/ ... uIndex1=24 and enter your vehicle... It will download the manual and you can go to the Fuses section and see them listed. This should be it go to page 108 :wink: http://www.motorcraftservice.com/pubs/c ... coog1e.pdf
if not a user i had to do it this way page 104 / 105. http://www.motorcraftservice.com/pubs/c ... coog1e.pdf
basketcase0302
fordman on Sat Jan 08, 2011 11:18 am
I don't even see numbers on the fuse panel, (under the drivers side dash). Maybe it's my eyesight?! :lol: Trying to power up both the cigar lighter and the 12 volt power source plug in the dash of this dilapidated old company van. I had to remove the engine computer to even get to the plugs / hooked up the wire (unhooked or had fell off the terminal) to the cigar lighter, still no power there...I was afraid to check for voltage before remounting the computer, (appeared the mounting screw might also be a grounding connection for the computer)?
I was unable to get to any of the above links, (asked to login). Are those free websites to register on?
Thanks guys!
Thunderfoot
:? It's a Free site no registration needed... :hmm: If you click this link it should load a PDF file of the owners manual. http://www.motorcraftservice.com/pubs/c ... coog1e.pdf
If you can't get it send my your email in a PM and I will send you the file... 3,500KB
start at http://www.motorcraftservice.com then on the left side of the page click owners manuals. then enter the year and make of vehicle. scroll down the pdf. to page 104/105. the cigar lighter is fuse number 23. its a 20 amp fuse.
69rangerf100
Post by 69rangerf100 »
hey Jeff you may want to hit up 71fordkid he has access to ALL Ford literature from 93-present, even Class A motor homes. PM if you have questions.
David
basketcase0302
Don't know why the link wouldn't work the first time I tried... :hmm:
Both links worked fine this time, thanks a lot guys! :thup:
