Draining this old man dry.....
Tpdaniels
Re: Draining this old man dry.....
Post by Tpdaniels »
I had the exact same problem, it started when I started to disassemble my truck for restoration. I left the battery in but had everything unbolted or removed. all the wiring was still hooked up but hanging loose near the battery. Leaving the battery hooked up with the regulator unbolted and mainly UNGROUNDED shorted the regulator and it would drain the battery dead from a full charge in less than 30 minutes, all the electrical components must be grounded or it will do the same thing to a new one. I have had no more problems after replacing the regulator and grounding everything.
I am of an age now that most of life's lessons were learned the hard way;
Life is hard, but it’s harder when you’re stupid.
Never approach a bull from the front, a horse from the rear or a fool from any direction.
Never ask how stupid someone is 'cause they'll turn around and show you.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
If you had the choice “Looks or Brains” take the Brains, Looks will get you thru the first half, but Brains will last a lifetime.
69rangerf100
Post by 69rangerf100 »
are you running headers? if so my suggestion would be to check the wire running to the starter. mine actually burned on to the header and was draining the battery in no time
David
jbohall001
Post by jbohall001 »
REALLY?? I hadnt thought to check that. Im gonoing to be working on it tommorow so I will check because I am running headers. I also have to figure out why my brand new temp guage isnt working. I think it just may be in a bad spot.
Vi hilser til Day
Vi hilser sønner Day
Vi hilser the Night og hennes døtre
Se på oss nå, med myke og ømme øyne
Velsign oss som sitter her
Vi hilser gudene
Vi hilser på gudinnene
Hilsen til deg; hellige Earth
Gi oss en gave av kunnskap og visdom
og la oss få hender som kan helbrede.
dont the sender and the gauge have to match as far as output voltages or something like that. maybe that is the gauge problem.
jbohall001
Well actually I bought a aftermarket guage and its mechanical. So it should read... I think. Im gonna check it out in the morning
Vi hilser til Day
Vi hilser gudene
