Sending Unit = Switch ?
Hawkrod
Re: Sending Unit = Switch ?
Post by Hawkrod »
Racer Z wrote:I use plumbers Teflon tape.
Tape is the worst thing you can use. The manufacturers will specifically tell you not to use it on electrical sensors because it can insulate the sensor and cause eroneous readings. Always use a liquid sealer that will allow metal to metal contacts between the sender and the hole it is installed in. Hawkrod
From Stewart Warner:
http://www.sw-performance.com/upload/B- ... 0Gauge.pdf
"Sender is grounded through its threads to the engine. DO NOT
use sealing tape on threads."
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
http://www.supermotors.org/registry/veh ... 9&detail=1
Racer Z
Post by Racer Z »
Understood now. Do you mean something like this:
http://www.permatex.com/products/Automo ... ealant.htm
pelesl wrote:Thanks for all the feedback.
What kind of conductive sealant do you guys like using on these guys?
teflon paste sealant. not tape.
pelesl
Post by pelesl »
Racer Z wrote: Understood now. Do you mean something like this:
Sounds like that's a good one. Says it's good for oil sensors, so I'm sure it'll be fine for coolant (which I guess falls under "intake manifold switches), too. PTFE is the generic name for Teflon.
