So today I accomplished two things. Installed a 3G alternator and wired it up and installed 390Nut's headlight harness. Here are some pictues...
Two Projects done 1971 CS
- Hemmi06
1971 F250 Camper Special
360cu with RV cam and 4v Carb
- Hemmi06
Re: Two Projects done 1971 CS
One more Picture:
The smaller black box house a Mega Fuse (175 amp) for the lead from the alternator.
Next thing to do is install the Mark VII radiator fan that is sitting in the garage. Have to save up for the controller.
I did not cut one piece of the OEM harness because it was a goal to keep it in one piece. Plus if I ever decide to go back to totally original I can.
Could not have done it without this site and all my lurking here for information.
The big black box has a single terminal for all the crap that was attached to the soleniod, helped cleaned it up a bit. It also houses two 12volt breakers one for trailer brakes and the other for the 12volt power to the key switch.The smaller black box house a Mega Fuse (175 amp) for the lead from the alternator.
Did that alternator come with that pulley. Reason I ask is I want to ran two belts but can find a pulley with two groves for belt.
- Hemmi06
The pulley came from the original alternator. No shimming needed.
- FormerMarine1981
- Hemmi06
Thank you... I have a little AAADD so it was tough...FormerMarine1981 wrote:Nice work, very clean install.
