Headlight switch
- OldRedFord
Headlight switch
What holds the headlight switch in place? Mine is pretty loose. Like if I turn the knob to adjust the dash lights the whole thing spins around.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: Headlight switch
Push the little button in on top of the switch to remove the knob and stem. When it's out, you can see a slot in the inner bezel cut across the hole where the stem was. Using a large flat-tip screwdriver, just tighten the bezel up, and reinstall the knob/stem.
