rim width
rim width
I know this is a stupid question, but what is the stock rim width on a 67 f100?
Justin
http://www.fordification.com/forum/view ... 22&t=47482
http://s976.photobucket.com/home/bb429power/allalbums go to both of the albums.
1967 Ford F100 longbed with a 466 500+hp/600+ft-lbs (mine)
1969 Mercury Cougar xr7 with a 351w (dads, I helped alot)
1970 Ford Maverick with a 302 (became our drag car)
1986 f150 5.0 (my DD)
"Many can argue, but it takes a real man to apologize."-Me
- 72Highboy
Re: rim width
I am going to say 15"x7" or 15"x8" Not sure havent had many stock rims Someone will post your answer soon.
Joshua
aka Young Gun
FE - Famous Engine
(Brandi) 72 F100 360 5.9L Sport Custom 6" Lift
U.S. Army Veteran/11B
aka Young Gun
FE - Famous Engine
- 1982 flareside
Re: rim width
15x7
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
Re: rim width
What the heck? This post was put in the drivetrain section at the same time as this one.
Justin
Re: rim width
Now when I post something on this thread and when anyone else does, it goes to both. And when it redirects me I end up in the drivetrain section. Plus, this doesn't go to the top of the list in the general discussion when something gets posted on it.
Justin
Re: rim width
fordman wrote:5 1/2 wide
Maybe 6" but I doubt it
this was back when a L78 (P235) was an oversize tire.
Re: rim width
well I measured the tires width and they are like 10" or 8" wide section width, not tread. I will measure them again when I get the chance, but I needed to know because I wanted to know if I could use this one set of tires I was looking at. On second thought, I think I heard from someone that they bought wider rims that were 10" wide and the originals were 7" wide. I don't know though.
Justin
- ezernut9mm
Re: rim width
i had the stock rims off my 68 and they were stamped inside 15x5 1/2.
Re: rim width
WHYYYYYYYY!!! I need at least 7.5 inches for these tires that I want. I have a great idea for the stock tires that will look cool too.
Justin
- 72Highboy
Re: rim width
Ok if you have the tire it should say what size. Example mine on my truck are LT315-75-R16. My rims are 16"x8" My actual tire with is 15.5" I can actual change my rim to a 16"x10" and still use my LT315-75-R16'S. So if you have a tire that needs a 15"x7.5" rim I am pretty sure it can squeez to 15"x8" if you cant find that size. If you must need the 15"x7.5" rim for your applacation try a couple searches on google to see what comes up. Best of luck.
Here is a website that might help http://www.offroaders.com/tech/AT-MT-Ti ... inches.htm.
To me 15"x7.5" I have never heard of that
Joshua
aka Young Gun
FE - Famous Engine
aka Young Gun
FE - Famous Engine
- DuckRyder
Re: rim width
The one in General is a shadow topic (see the little icon) showing it was moved here, which come to think of it isn't right either, it should be in suspension (so there is going to be one here showing it was moved there in a minute). When you click on the shadow topic it brings you here, because there isn't really anything there.bb429power wrote:Now when I post something on this thread and when anyone else does, it goes to both. And when it redirects me I end up in the drivetrain section. Plus, this doesn't go to the top of the list in the general discussion when something gets posted on it.
As for the wheels, there were options, so it is difficult to say what size they are without measuring. They aren't 7.5 though...
Re: rim width
The recommended minimum requirement for the tires that I want to get is 7.5 inches. Not saying I need rims that exact size. They should be between 7.5 and 9.5 inches wide rims for these tires. How do you know what your rim width is by looking at the tire? Never heard of that but I know you can find the rim diameter off of the tire. Oh wait, that's not what you meant, but I wonder if you somehow could. What I hate is how they will say the tire size is LT315-75-R16 and its in metric so I get confused. And then they throw a standard measurement in there for the rim width to throw you off. Is there a way I could get stockies but wider?72Highboy wrote:Ok if you have the tire it should say what size. Example mine on my truck are LT315-75-R16. My rims are 16"x8" My actual tire with is 15.5" I can actual change my rim to a 16"x10" and still use my LT315-75-R16'S. So if you have a tire that needs a 15"x7.5" rim I am pretty sure it can squeez to 15"x8" if you cant find that size. If you must need the 15"x7.5" rim for your applacation try a couple searches on google to see what comes up. Best of luck.
Justin
- DuckRyder
Re: rim width
Re: rim width
I was hoping that I could get wider stock wheels for a low price but if I'm going to spend the same amount of money then I will probably go with something like a modular wheel or maybe a smoothie style.
Justin
