need some advice on engine parts
- 69rangerf100
i have a 390 and mentioned in my signature
1. what is the best type of freeze plugs to put in the block.
2. best type of aftermarket stock bore
3. best brand for cam bearings.
that what i can think of for right now about to start the rebuild on the engine.
David
- 1971ford
Re: need some advice on engine parts
freeze plugs... get some brass ones from a local auto parts store. the size is 1 48/64 or its 1 49/64 i forget but it is NOT 1.5 like they might tell you at the store.
After market stock bore?
-Ryan
- OldRedFord
Maybe he ment "best aftermarket stock bore pistons"
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- BobbyFord
Clevite cam bearings.
If you are looking for pistons, I would measure the bore first, I can't imagine that you have a used stock bore that is still within spec.
- 69rangerf100
you are correct OldRedFord i was extremely exhuasted last night when i posted the thread last night
David
- 69rangerf100
ok dumb question when it come to pistons im clueless how do you measure the boreBobbyFord wrote:Clevite cam bearings.
David
- BobbyFord
Assuming that you do not own a bore gauge, you willl have to take the block to an engine rebuilder/machine shop. Most stock bore blocks that I've seen have required a .030" overbore.
- 69rangerf100
how much and where could i get a bore gauge?
David
- eggman918
Find the closest machine shop go see them about closing time,I bet they will measure them for you for a 6pack if not for free69rangerf100 wrote:how much and where could i get a bore gauge?
We did favors for people all the time
Steve
The"Filthy Beast"- '68 F-250 Crew Cab 131"W/B 4x4 4BT compounds hx30/Wh1c,5x.012" sac injectors/ZF 5/NP203-205 /3.54 44 trutrack front/60 trutrack rear on 33's. 2nd owner
"Beauty is only skin deep....Ugly is to the bone"
It is more important to understand what you don't know than what you do know,because then you can start to learn..???
"you must deal with the attaboys and the ass chewing s with your head up and looking them in the eyes" T.J.E. aka My Dad
There are only three types of people wolves, sheepdogs, and sheep. What are you?
- BobbyFord
Measuring cylinder bores is not as easy as purchasing the tool. You have to know what to measure. You need to be able to measure for out-of-round, bore taper, bore diameter as it pertains to each individual piston, etc. I would recommend taking it to someone who does this sort of thing everyday.
For the price of the tool you could pay someone to do it correctly. JMO.
- eggman918
Bobby Ford is correct it is a task that requires training.
If a shop wont do it for you Cheep they are WIENIES
Steve
- eggman918
A smart motor shop would do it for free to gain a little goodwill and your future work
Steve
- 69rangerf100
what is the best way to find an engine shop i have tried several time looking online and the phone book and have come up with no luck at finding one. any help would be much appreciated
David
any mechanic who rebuilds enignes should have the tool and knowledge. i have no idea who to tell you to go see for the best or a good person who knows what they are doing.
- 69rangerf100
i appreciate all the help and the engine is definately one part of the project where i want it to be right the first time that what it doesnt cost me later down the roadBobbyFord wrote:Measuring cylinder bores is not as easy as purchasing the tool. You have to know what to measure. You need to be able to measure for out-of-round, bore taper, bore diameter as it pertains to each individual piston, etc. I would recommend taking it to someone who does this sort of thing everyday.
David
