Resistor Problem
Resistor Problem
I was testing voltage today on the truck and i realized that for some reason the resistor(Ballast resistor) is cutting down 6 volts all the way back to the battery.. Any ideas?? im at a loss on this one
- BobbyFord
Re: Resistor Problem
Um.............whaddya mean ballast resistor?
its a stand-alone resistor that mounts to the firewall. and it runs from the ignition to the coil.
- BobbyFord
Shouldn't be there. The stock coil wire itself is a resisted wire.
okay so you are saying that i need to remove that and run resisted wire all the way to the coil and that will be enough
The stock wiring on the truck has a "Resistive" length of wire in it from the ignition switch to the coil.
If you are measuring 6 volts at the coil then you are good, as that is what it should have (6-9 volts), somebody probably replace the original wiring with the ballast resistor and a new non-resistive wire.
You did mention that this 6V voltage was all the way back to the battery so not sure what you are referencing there?
- Dragon
Probably measuring from the resistor out side back to the battery. From the other side maybe it is 12 Volt. Here is another thought maybe there was a hot coil on the system that required a second resistor. So maybe the original resistor wire is feeding the firewall mounted ballast resistor.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
