Freaky right turn signal
91Bear
Post by 91Bear »
OK, I took the ol' girl in to get inspected today. With the engine off, and the key turned to ACC, the right turn signal shows a solid arrow on the dash but nothing on the front or rear. The left one blinks. Emergency flashers work fine.
With the engine on, both turn signals work as they are supposed to.
Any ideas?
They went ahead and gave me the inspection sticker, but it was touch and go there for awhile. :lol:
70_F100
Re: Freaky right turn signal
Post by 70_F100 »
Move to NC.
Anything older than 35 years doesn't have to be inspected!!! :D :D
i have read about this problem before and i keep forgetting the answer. i want to say either a feedback loop in the wiring or something in the tss feeding back. i think.
Chaseman
Post by Chaseman »
My car will do that when there is a burnt out bulb. So there isn't enough draw to trip the blinker thing. Also my stuff blinks slower with the engine off so perhaps that side somehow doesn't have enough draw with the lower voltage compared to the higher voltage with the engine on. Also this theory could be intensified if you or a previous owner put in a HD blinker thing which barely blinks to began with when no trailer is plugged in.
