emergency flasher switch
Can a 1970 dash mounted emergency flasher switch be used to replace a glove box mounted 1969 switch?
Re: emergency flasher switch
you should be able to . i think it will fit in the bracket. the plug is the same. so thats not a problem.
You'd just have to partially unwrap or slit open the 69's wiring harness to get the wires to stretch over.
- sport71
Those who do not learn the lessons of history, are doomed to repeat it.
Thanks folks, really appreciate the info
