help please
help please
i had my truck running yesterday and this morning i went to turn it out and it not even crank or nothing i took the battery to go get it tested it was fine. i replaced the started today thinking it was that but no i check all connection to see if it was loose fine. i got a new coil ignition and starter relay today also thinking it was that but no also.what could be the problem and oh yea and the starter is fine also. help please
Re: help please
just like in the other thread the nss could be the problem. to check if it might be pull the shifter on the column over to the drivers side while you turn the key. if it starts it is out of adjustment. or put in nuetral. that works too. if its not a automatic i might look at the switch or the wiring to the switch. soemtime you can wiggle the switch up and down and get it to work while your turning it. they go back and get slack in them. try that stuff and let us know.
