Dual horns???
- l1k2gadd
Re: Dual horns???
papabug71, the larger horns in the picture you have there look almost like the horns that were installed on the early Falcons, Comets and the 1964 & 1/2 Mustang. I know those horns were bigger in size than the later horns. I believe the earlier 60s Ford trucks had larger horns on them too.
- FLATBEDFORD
Re: Dual horns???
I was wrong. I only have 2 sizes. The little one is what my truck has, and I got a couple of these big ones in the box of stuff I bought.
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18.
Passed on to new care taker July, 2013
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
My Photo Gallery
- papabug71
Re: Dual horns???
I wonder if the F-600's had them. The in-laws have a pasture full of them. Im going to check it out.......
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
- Supermike
Re: Dual horns???
My truck ('67 Camper Special) has dual factory horns. One "Hi", one "Lo". I had to replace my "Hi" horn, and they sounded great when they worked. But now they've stopped working again.... I'm guessing it's a contact brush, but it's been too $#&*@ cold to mess with it right now.
Anyhow, there is a singular wire that runs from one to the other.
Current owner of a 2022 Ford Bronco Wildtrak
- dolinick
Re: Dual horns???
I found a horn that looks a lot like the one on the left from a slick, mid sixties, f100. I don't remember the exact year of the truck. I put it in my '68.papabug71 wrote:Found a pic of the one I had. This one is from ebay & im using the pic as a refeerance.
Mine is (was) the big one on the left. It was a super low note & it went BLAAAAA!!! Thats the best way I can describe the sound....
Dan
2003 7.3L F250
1968 F500 Utility Truck
Re: Dual horns???
I didn't realize that they were adjustable. How exactly do you do that?bjde0b wrote:I have dual horns on mine. I simply ran a hot wire from horn 1 to horn 2 and adjusted the diaphrams until I had to tones that I was pleased with. You can see pictures on my website.
55F100
55F100
- Supermike
Re: Dual horns???
There is a little screw on each horn that puts pressure on the diaphragm... that will adjust the tone from a squawking goose to smooth... you just have to play around with that screw to get the right tone. It helps to have a helper so you don't have to make 100 trips back and forth.Fordnatic wrote: I didn't realize that they were adjustable. How exactly do you do that?
- FLATBEDFORD
Re: Dual horns???
You might want ear plugs too!
Steve
My Photo Gallery
My Photo Gallery
- Supermike
Re: Dual horns???
haha! NO DOUBT!! WHen I was working on my horns and used a jumper wire to make them sound off, I about wet my pants it was so loud. I think my heart actually stopped beating for a second.FLATBEDFORD wrote:You might want ear plugs too!
Re: Dual horns???
My truck came with two horns on it. I got it from my grandpa. They look factory. It sounded nice but not nice enough. I found a glorious box of old horns at a swap meet once and bought all i could hold. I think before i took the truck apart for restoring i had 5 low tone, 6hi tone. and four air horns running off of two separate compressors. It was about as loud as a train but did the sound did not carry for more than a mile or so.
Re: Dual horns???
My '75 came with one horn and I added another used one after I bought an Echlin horn relay.
Under warranty they replaced the horn relay a couple times but it was a pain to get a "free"
relay so bought one from NAPA and it's still in there working. :)
I moved the original out where others;) could hear it while I was at it...
http://www.panix.com/~alvinj/file12/horns.jpg
Alvin in AZ
Alvin in AZ
Re: Dual horns???
here those large horns are they are slick horns. this is from a 64 f350. i have seen several since i took this picture a few weeks ago but htey are all the same as the rest of them everyone has posted. and this one too.
