What the biggest motor you can cram into a 68 F100 is? It has the 360 in it currently.
Just curious.
Does anyone know..
Does anyone know..
1968 F100 Short bed Bump
- Dragon
Re: Does anyone know..
Any Ford Truck engine or car engine will go in them.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
are we linited to older ford engines or can we go out on the modify the inner fenders and frame binge? how about a 4 1/4 over the road cat engine? it will fit with a few mods.
428 is as big as I ever went. I suppose the Cat engine might be alright but don't know how it would handle with a tandem steering axle on the front end!
You could go to a 534, but it was physically a very large engine and heavy.
Fred
Fred
- DuckRyder
How much money do you have?
As has been said any gasoline powered ford car or truck engine will fit with varing degrees of dificulty. All the older stuff (FE's, Windsors, Clevelands, Limas) is just a matter of finding the right combination of parts.
- FORD428CJ
Seen an SOHC 427 squeezed into one! WOW was that cool. I'll have to find the pix on line, if I can.goodtimejonny wrote:What the biggest motor you can cram into a 68 F100 is? It has the 360 in it currently.
Just curious.
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
- 71 LONG BED
Check out this post!FORD428CJ wrote:Seen an SOHC 427 squeezed into one! WOW was that cool. I'll have to find the pix on line, if I can.
John Member #1549
- Dragon
That is an easy stuff the engine in trick. The SOHC is the same width as any FE at the block mounting area. The Heads overhang the block but F series truck have plenty of room on the sides for clearing a FE and more that enough room on the front for the chain case.
I drove a SOHC 54 F1 with top loader and that was a really tight fit.
Try stuffing a SOHC into a 67 Mustang it fits but if not for the top plugs you would never tune the engine.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
