Intake question(FE)
Intake question(FE)
Anyone here using the Edelbrock Streetmaster intake? If so, how do you like it? I scored one at the wrecking yard recently and want to use it on my '71 F250 390. Thank You in advance.
-Lance
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
- FORD428CJ
Re: Intake question(FE)
Give it a try!!!! I have the Holley intake like that (Street Dominator). If you have headers, bigger then a stock cam and a decent carb on it, give it a shot! They work better then what most people think........JMHO
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
Cool, thanks.
-Lance
-Lance
- FORD428CJ
You Bet......Any Time and good luck!!!!
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- BobbyFord
Isn't the Streetmaster a single-plane manifold?
- FORD428CJ
BobbyFord wrote:Isn't the Streetmaster a single-plane manifold?
Yes it is. Check out Fordfe.com for the Dyno test. Quite a few members use them on there trucks and heavy cars. They like them and use them for street use all the time. Its street friendly.....Believe it or not LOL.
The Holley is the same way!
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- FORD428CJ
Its not like a Dove Spider intake (Race only) or like the Victor. And if you have a 3 side by side, you can see why! JMHO
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- BobbyFord
But is it a single-plane intake? The older ones (early 80's) were.
- FORD428CJ
BobbyFord wrote:But is it a single-plane intake? The older ones (early 80's) were.
Yes its a single plane intake. I think they where made in the 70's (maybe early 80's) and have a small plenum to them.
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- BobbyFord
I bought one of those in the 80's for my 67 390 Mustang. I was running a 650 Holley carb, factory 427 solid lifter cam, dual-point dist, etc. I saw a very noticable loss of low-end grunt. The Streetmaster quits at about 4500 rpm's. I eventually wound up going back to the stock cast iron intake. I certainly wouldn't run a Streetmaster in a heavy vehicle, such as a truck. On the dyno the Streetmaster performs pretty good but in a heavy truck I see no advantage. I would be more apt to run a dual-plane RPM intake in a heavy truck.
- FORD428CJ
I use to run an F-427 intake with a 2" spacer on it. That worked well.
I do believe that Ross (My427Stang) Runs a street master on his old Ford 4x4 with a lift. I see if I can find a link to his set-up!
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- FORD428CJ
Here is a link to his truck with that intake on it! Ask him how he likes the intake. I know its a Holley but I think the Ed street master is close to the same.....
http://www.fordification.com/forum/view ... ng#p246115
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- BobbyFord
I just speaking from personal experience.
i had one on my old motor, seemed to be fine. of course my truck is 2wd and a shortbed. it seemed to run ok up to 5500. but i have a heavy foot
- Dragon
I used a Torker for FE and when Edelbrock dropped it they had the Street Master as a replacement and the performance difference was nil. The Torker with 780 Holley Crower Baja Torque Master cam, Hooker Tuned Headers 8.25 to 1 compression, Accel dual point dizzy, 3.78 to 1 9 inch locker and with a car Top Loader 4 produced a 68 SWB 140 mph truck. It had so much low end torque that it felt like I punched it when I let the clutch out at an idle towing a 53 Dodge panel wagon home for a friend.
Small Plenums on straight runners has been the hallmark of the Low end torque manifold for Edelbrock's Torker line for years. Long Straight runners with large plenums will kill the low end. So Torkers and Street Masters are not High manifolds with long runners but lower manifolds with Shorter runners.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
