INTERESTING Issue with my 390 v8
LUVMY69FORD250RANGER
Post by LUVMY69FORD250RANGER »
besides my tranny issue. as i was trying to get that going. little bit of smoke was coming from the metal cap where the pcv valve is connect to the hose to the manifold ??? do i need a pcv valve ??there. seems to hinder the flow.
THANKS
71Ford100
re: INTERESTING Issue with my 390 v8
Post by 71Ford100 »
If it ain't broke don't fix it. Is the engine runnin like normal if so don't screw with it! I am kinda confused what you are asking due to the poor grammer. Can someone help me out with what is being asked?
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
basketcase0302
Post by basketcase0302 »
Luvmy,
Do you have oil in your air breather?
Re: re: INTERESTING Issue with my 390 v8
basketcase0302 wrote:Luvmy,
YOU THINK breather is clogged. pcv clogged. ?? those are ok to spray out right.
THANKS
fomocoguy
Post by fomocoguy »
Yes, go ahead and spray some cleaner in your pcv valve. Just remove it first. Shake it and it should rattle. Or, you could just buy a new one; I think they are about $3. If your engine is well worn, the smoke you're seeing may be blowby. It happens when the rings get worn and pressure slips past the rings into the lower end.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
