knock in 300
- 67RED
knock in 300
hey guys i got up yesterday started old red . it had a really bad knock toward the front of the engine on the bottom. at first it was just a knock now and then. then it became a steady knock.i shut it off now im trying to figure out if want to rebuild or replace. thought you guys could give me a little feedback. thanks may have to sell the 66 to fix the 67
steve
Life is 90% how you take it10% what you make it
- ToughOldFord
re: knock in 300
Fuel pump is a good place to start. My 352 had a pretty serious knock, turned out to be a wore out fuel pump.
You can isolate it pretty easily using the wooden-pole-stethoscope trick.
- averagef250
A rod knock is not just loud, but can be felt through the whole truck and gets considerably harder with RPM.
A rod knock is cyclic with engine RPM. Anything else, valvetrain, fuel pump, etc will be 1/2 engine RPM and will not usually be felt through the trucks frame/body.
- Ranchero50
- cathynkeith
I had great luck pulling the pan and just replaceing the mains, 300 is very tough. Han an 81 van, replaced bearing and distributor at 278k and went another 150k of very hard driving with 5 different delivery drivers, van got hit in the side in Arkansas almost went up there to pull the motor but too far and too much trouble.
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
- 67RED
re: knock in 300
belive it or not guys it was the oil pump collapsed. and i put a new one on. and it stop knocking
![yippy :yip:](./images/smilies/yippy.gif)
![Woohoo! :woohoo:](./images/smilies/icon_woohoo.gif)
![Happy Dance :hd:](./images/smilies/icon_dancing.gif)
steve
- RedneckTexan
