Distributor conversion
What's the advantage from going from a points-type distributor to an electronic one? What's involved? (Yes, I got the thought from reading those "Did you know" boxes at the top of the page).
1972 F250 Crew Cab
Family heirloom
Photo gallery: http://www.fordification.com/galleries/ ... ?cat=10482
Family heirloom
- Chaseman
re: Distributor conversion
I've actually delayed on getting electronics due on a comment made by my dad. He said " what if decides to break , short out , you have no way of fixing an solid state electronic unless you got a spare module in glove box. But with points you can depending on your skill you can mess with enough to get to town or just got spare points and condenser etc. I have really bad luck and if something can go wrong it will so I've stayed with points but thats just me and my
I installed a Pertronix unit in my pickup about four years ago. Have not looked at the dist since. I do carry a set of points and cond just in case, but have not had to use them yet. You can also gap the plugs somewhat wider and get a better spark with the pertronix. Seems to start a lot easier too.
Fred
Fred
converted to a duraspark setup. If ford engineering spends millions on the design, it ought to be good enough for me
spare module & pickup coil behind the seat (where it's ridden for about 10 years) no worries.
Even if you burn the electronic points out, a few hand tools is all it'd take to swap it back to points 'in the field'. Heh! Just as long as ya can get the dist back in pointing the same direction
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
'72 F250 Ranger
So, in the end, the benefits are a little better starting?
That doesn't sound like enough of a benefit to tackle that as opposed to getting the A/C fixed. Or getting a new steering wheel. Or replacing the passenger inner fender. Or getting the right rear window fixed. Or getting new window fuzzies all around. Or saving up for a new paint job. Or replacing the air relief line on the auxiliary tank.
But it's still damn fun to drive. Besides, I like the stares it gets.
1972 F250 Crew Cab
Family heirloom
Family heirloom
do 240 & 300 6s use the same distributer ? Meaning could i just drop in a later model 300 dizzy into mine?
67 F100 240 I6 3spd now gone
1971 F250 LWB FE power by FORD
Re: Distributor conversion
i read somewhere that you could run an hei ign module instead of the ford module
http://www.fordmuscleforums.com/ignitio ... -case.htmloldyeller69 wrote:i read somewhere that you could run an hei ign module instead of the ford module
Steve
1969 SWB F100 Ranger. 240-6, C-4, 9" N-case 31-spline Traction-Lok w/3.50 gears.
1968 Mustang. My high school car. Owned since 1982.
2003 Azure Blue Mustang Mach1.
- pincheweddo
I have one on my '47 ford tractor for years and as of last week, one on my 351w Bump. It is a more efficient system by removing moving parts and you never will question "did I get that gap right?" Anyway, I read this article a while back.http://www.jalopyjournal.com/?p=18500
If Mr. Jalopy Journal caved I am sure there are many others to follow.
