Electrical,but alittle off topic
67mann
Post by 67mann »
I have a Campfield-Hauss 26gal/5hp compresor,made to plug into outlets. I was told along time ago I could rewire for 220(but have had no ample power source until now)and it would run more efficent. There's nothing in the manual that say this can or cannot happen(Wal-Mart special) Has anybody done this or can give me info about it?
Supermike
Post by Supermike »
I dunno, but this discussion might help:
http://www.homediscussion.com/showpost. ... stcount=42
Current owner of a 2022 Ford Bronco Wildtrak
67mann
re: Electrical,but alittle off topic
Post by 67mann »
THX for reply Mike,but a buddie stopped in and the motor is not set up for
220--just 120---so I just put it on it's on 20amp breaker--that'll do for now
I may have to look into bigger/better someday :thup:
basketcase0302
Post by basketcase0302 »
Most all electric motors have a data plate somewhere on them that will specify volts/amps/and HZ.
If there's no data plate there...
When you look at the end of the electric motor that turns the compressor, most have a small plate covering where the supply voltage is wired into the motor.
If it's a multi-voltage motor there will be several terminals under that cover plate.
A lot of motors it's just a matter of switching where the leads are hooked up under that plate. :thup:
