is this an OE bench seat for a truck?
- kilog55
havent seen a seat like this one until now it has 3 inverted chrome rectangles for "trim" and is all vinyl. just wondering if it is a factory seat for a truck or is it from a car?
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
re: is this an OE bench seat for a truck?
That's not a period-correct OEM seat. Some of our trucks did have seat-back medallions, but not like that.
Considering the red door, green column and steering wheel, floor-shift conversion and this seat, I think it's safe to say that your truck has been heavily modified by a previous owner with whatever he could find..
- peanutman
Looks like a seat out of a late 70 early 80 chevy truck. They used those medallions on there interior.
http://s533.photobucket.com/albums/ee33 ... e_Johnson/
1970 302,ps, ac, 3 speed o.d.
- kilog55
yeah my truck is a Frankensteen
- cghstrojan08
Definitely not the right one.
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
It did shout chevy to me when I saw it. Look at the mounting area to see if it is fabbed in or bolted right up
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- kilog55
yeah i gotta pull back some white shag carpet and the OE rubber mat and check for OE mounting holes
- kilog55
Re: re: is this an OE bench seat for a truck?
cdeal28078 wrote:It did shout chevy to me when I saw it. Look at the mounting area to see if it is fabbed in or bolted right up
clint
yeah its bolted in a good 3 inches in front of the OE mounting area if your familiar with the factory mounting area where the depression is. my seat is bolted in front of this area
It does look a lot like a Brand "C" seat
When my truck grows up, it wants to be a Crew Cab like Teacherman's
- kilog55
yeah im workin on getting some 67-79 seat brackets so i can atleast put a newer FORD seat in
