72 seat upgrade
72 seat upgrade
what are some model/make/year of seat with a headrest that fits & looks good in my 72 ranger xlt short bed 2 wheel drive automatic on colum? thanks.
- wt4speed#2
Crazyhorse
Mine is an '80 some thing seat in the pics below the blue suare is the '80 some thing track and a stud goes thur that hole. knck the stud that comes thur that hole out of the seat frame and the stud(in red square on the 67-72 seat tracks) slips right in. Any thing center to center measurments on said studs that match the '67-72 will bolt right in.
http://i201.photobucket.com/albums/aa28 ... 93x600.jpg
http://i201.photobucket.com/albums/aa28 ... kmount.jpg
re: 72 seat upgrade
thanks, i was hoping to put one of the new[er] seats in mine with the nice headrests in case i get hit from behind . might protect the back on my head. thanks for those pictures.
re: 72 seat upgrade
re: 72 seat upgrade
thanks,
- 72stepside
re: 72 seat upgrade
I did the following with seats from a mid-80's Crown Vic...
I used the mounting brackets on the seats by fabricating a perch using square tubing, angle, and long grade 8 bolts.
These sit a little high. I should have cut another 3/4 inches off the perches. These would not have worked with a stock steering wheel. The small wheel allows room for clutching and no rubbing of my thighs. They are quite comfy.
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
Hedman Headers
Disc Brakes
re: 72 seat upgrade
thanks for all the information. that really helped. sure do like your seats & console & tank cover.looks good. thanks again for taking your time to help me.
- MadMaxetc
Check out my website for what I did.
I used a 94 seat and tracks, just mounted them to the original brackets
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- kilog55
will any other year brackets work or just 67-72? like say 61-66???
and is the bracket assembly bolted onto the seat as well like the floor. cause i have a c&*(y seat in my 72
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
