help
fourtss
help
Post by fourtss »
I have a 97 dodge ram, I know, please no comments, anyway, it would not start the other day, put a new coil wire on it started fine for one day, now it won't start again, could it be a bad coil, and what is the coil pickup in the distributor do.
:? :? tom
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
i dont know what the pickup does but. i know if it goes bad it wont start. i had to replace one on a olds once because someone had there finger in there and pulled the wire out of it.
fourtss
Post by fourtss »
figured it out, it was arcin up a storm under the hood just above the dist cap
tom
2003 ford escape
cghstrojan08
re: help
Post by cghstrojan08 »
Glad you got it figured out.
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
