Can't figure it out
- cghstrojan08
Can't figure it out
The stupid dome light stopped working. The bulb is good. What should I look at?
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
- cghstrojan08
re: Can't figure it out
No, if I turn the headlight switch to turn it on it still doesn't work.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- basketcase0302
Robert,
Do you have a voltage meter to verify if there is 12 volts at the light socket? (Could be a bad ground or bulb if you have power there).
Also while you have the bulb out checking for voltage there, look at the grounding on the light assembly itself. (Make sure the light socket is grounded to the cab there).
Go backwards from there to the door switches themselves and check for voltage. (No power at these switches, probably in the headlight switch).
Hope this helps.
Hope this helps.
- l1k2gadd
If you have door jamb switches in a BUMP the switches get their power from the "always hot" green wire with the orange stripe up under the dash. It is a fused hot and MIGHT be fused by the DOME fuse. The dome light through the headlight switch I believe is fed off of a fuse as well. The small fuse in the fuse panel is for the instrument lights only. My fuse panel in my 1968 is labelled. The DOME fuse is bottom left. I can read the teeeenie weeeeenie letters with a flashlight shining on the fuse panel from an angle.
- 69twotone
I found this out the hard way and I am sure you have already tried this but........ I replaced the bulb in my heater controls and nothing. The cab light and the heater controls work similarly with respect to the fact that they both have to ground out on the metal of the cab.
I looked around and followed all of the wiring back to the fuse box. Everything seemed good still no light. It was getting dark so I stuck the light socket and bulb back into the hole and bingo light.
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
- 1971ford
- cghstrojan08
I will probably look at it over Christmas break. I have so much crap to do right now for school. Thanks though for all of the ways to check it. I am almost sure though that there is no power getting to the socket at all.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
