http://cgi.ebay.com/ebaymotors/ws/eBayI ... OTORS:1123
I wanted one of the silver faced ones, but couldn't pass this up. If it doesn't go in the '71 it will end up in the '93 stang. Did one to my dad's '89 coupe and it fit really nice. Figured I'd try to fit it before painting.
Jamie
Anyone ever try to install one of these stereos?
- Ranchero50
- aramil
re: Anyone ever try to install one of these stereos?
i think it is a double din, if it is its too big to go in the dash.
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
- Ranchero50
- Ranchero50
Thanks for the link, this one has the internal amp so the wiring is pretty basic once I get the plug. Dad got a 6cd for $30 shipped and he swapped it out of his '99 superduty in about fifteen minutes and put the plain CD player in the stang. This one was at $9.99 and I hit it up to $30 three hours before it went off and with a bunch of others around it with high bids I didn't expect to get it, especially for $12...
I'm sure I can make it fit, the back isn't full height so I may even be able to put some tweeters under the dash.
Jamie
Jamie
- Ranchero50
Been playing with this idea some more. Ended up getting another center dash section today to chop apart and graft into the original dash to make room for this stereo to fit. I figure I'll graft the stereo in and then whittle a factory looking bezel out of aluminum. I also found a decent AC heater control on the dash I sawzalled apart.
Photochopped... Figure I'll move the bottom sweep over under the glovebox, lower the ash tray and heater control and graft in the missing peices from the black dash. The holes above the ash tray will be for the diesel glowplug and water in fuel lamps. I'll have to fab up something in aluminum for them as well.
Gonna be a lot of fine cutting and fitting back together but it's the direction I want to go with it. Custom. I already made a particle board blank for the stereo faceplate and it fits side to side in the original radio hole, it just needs more hieght. I also considered changing the heater controls out to something that would fit where the ash tray was. The guys at the junk yard couldn't fathom what I'm going to do and never heard of someone cutting a dash section out to repair a radio hole.
Jamie
Jamie
- cghstrojan08
Looks good, have fun.
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
- Ranchero50
Mike, check out my thread over in the project updates forum. Decided to put the heater controls above the stereo and the ash tray over by the glovebox. It looks pretty good, but I haven't had time to work on it due to the dome lamp bezel project.
Jamie
Jamie
- Ranchero50
