Turn Signal Switch
rjewkes
Post by rjewkes »
if you know basic circuit board wiring and soldering. you could go that route maybe back it with a painted piece of metal.
fuelly.com
even the originals were plastic junk. they are made to break so they can be a replaceable ford only item. you can use a different one. just roll down the window.
qman
re: Turn Signal Switch
Post by qman »
Junk is right. These things are crap.
72 F100 2wd 360 C6 Custom w/factory PS.
fmartin_gila1
Post by fmartin_gila1 »
Read the prior post. Not stock, but will last forever with our type use.
Fred
fmartin_gila1
Thought I would add to this. The Peterson switch is available from JCW, NAPA or most any other source. It is a very good and sturdy unit. LMC sells a switch that is chrome and about half the price of the peterson switch, so I would question the quality, although I have not seen nor inspected one of those units.
Fred
qman
Re: Turn Signal Switch
Post by qman »
what is a Peterson switch?
