questions about my truck
re: questions about my truck
The first picture is the brake system warning light.
Nobody here would have any idea what the previous owner of your truck hooked up to that switch. Have you tried following the wires to see where they lead?
- 1971ford
darn, i was hoping the first pic was switch for the valve or something. and i was hoping the second pic was a factory thing. I need to ask the PO why he did all this crazy stuff to the truck. yeah, but under my dash is a jungle of wires. the buttons wires lead to a bunch that are taped together and i havent traced it all the way yet. maybe this weekend ill take the time. what about the fog lights that were mounted on top of my bumper? maybe the button turns those on? i have no clue
ill take a pic of my wire jungle in a few minutes.
-Ryan
- dbarker
Re: re: questions about my truck
Keith, where did you find that L/R switch!?!? Im wanting that exact part! its not in any of the parts catalogs, though the main, aux one is.FORDification wrote:Don't worry...you're fine, just razzin' ya!
Actually, it's been my experience that the saddle tanks don't have a sending unit....they're for storage only. Here's a couple pictures of the dealer-installed saddle tank from a '70 CS I parted out a while back:
http://www.fordification.com/images/Ueh2_70CS01.jpg
http://www.fordification.com/images/Ueh2_70CS02.jpg
The factory auxiliary tank setups that I've seen had the switch under the dash with a bezel marked for the main and auxiliary tanks, pictured below on the right side. However, I have run across a bezel that is marked 'L' and 'R' for left/right tanks (at left in pic below), which I can only assume is for a saddle tank kit...a different variety than what's pictured above, with tanks set up with a sending unit. However, since there's no 'main' setting on that bezel....I'm thinking it's part of the dealer add-on tank kit, and the kit would include a new three-way electrical switch, with the middle position being the main tank. Can anyone else shed some light on this?
The way i was going to hook it all up is main reads main tank, Aux hooks to second switch, which you then tell it left or right. This would have been easy for a dealer to install. just put it inline off the aux position.
I had been thinking of how i was going to get one made, but if they already exist...
Drew
See My Gallery -http://www.fordification.com/galleries/ ... ?album=913
My Website: http://www.drewbarker.net
That picture was just something I saved from an E-bay listing a while back. At least now you know they exist, right?
- 1971ford
well since this post was brought back to life...1971ford wrote:ok here is the pic of what i think the selecter used to be. i dont know
anyone know what the square button is?
that round switch to the far left is the brake warning light, my dad was talking about a different switch.
in the second pic, that square button, i was able to trace one wire coming off of it which went to the fuel unit doohicky under the cab.
im quessing the square button goes to the aftermarket fog lights that i took off. just a guess though. but its weird because two of the wires coming from that switch go under the dash and just stop.
i really need to start ripping all the electrical tape stuff off the wires so i can trace everything.
well thats it for now.
-Ryan
- 1971ford
the wires that i traced to the headlights ( by the way, they only went to the left headlight, but i think if i traced more wires some would go to the other headlight as well) were coming off of the black switch not the button. on the button, i have traced 3 wires. two go to the glovebox and just end, and the other wire goes through the cab floor and goes into the fuel valvy thingy under the cab. i can get some pictures.
so thats all the wires i have traced. the others are more difficult because they are buried way up in the dash. ill get to them sometime though. tomorrow i will continue tracing
-Ryan
- 1971ford
- 1971ford
i couldnt wait. i pulled the headlight knob out half way and they were dull, i pulled it all the way and they brightened, and then i flipped the switch................ and found out the the switch is for the highbeams!!!!!!!!!! Thanks fordman for your help. now i FINALLY know what that switch is for!
that was so exciting. i cant wait to find out what the button is for. maybe oil slicks....
-Ryan
- 1971ford
