Installing new door seals
Tallboy
re: Installing new door seals
Post by Tallboy »
That's what was odd when I put my seals in...... :hmm: :?
Now I gotta redo them. :oops: It didn't even dawn on me that I could cut the loop to insert it over the metal.
Thanks Truckcrazy!
72 F250 4x4 Ford GT Red.
FE 428 Trust me it goes....
flistr8
Post by flistr8 »
Man, I sure wish I'd seen this prior to trying it on my '71. There's a nasty do-over in my future. :cry: I'll be posting pix soon. Nice tutorial, Sharkdance. Thanks.
studdmstr
Post by studdmstr »
Oh what a difference new seals make!
MadMaxetc
Post by MadMaxetc »
wow, this thread came back from the dead! :D
Dan
FORD Girl
Photobucket Pictures
marz68
Post by marz68 »
very good info Thanks!
donner5
Re: Installing new door seals
Post by donner5 »
Hi sharkdance, I realize it's been 5 years since you posted those pic and I'm new to this forum. I just got my new door seals from LMC and would like to see those pics you posted about your door seal. Any chance of that happening? Thanks in advance.
jzjames
Post by jzjames »
Sharkdance, youre out there, and Im putting my first set of new door seals on my 67. I immediately searched for your thread as I remember it when you posted it.
I bought a set of Precision door seals since some members recommended them.
The other project I'll be doing is a new interior firewall, and I remeber your tutorial, but I know all the pictures are gone. Oh well.
basketcase0302
Post by basketcase0302 »
Here's one pic that I thought might help guys. I've got a few more in my photobucket on when I did it.
Ranchero50
Post by Ranchero50 »
Good deal, mine are sitting in the box and I'm about half afraid to install them. I hate weatherstrip glue, could never get it to stick so I too am looking for any tips and tricks.
jzjames
Post by jzjames »
Finally got mine installed. I bought the Precision brand ones, and they were top quality. Used 3M "gorilla snot" for the adhesive, everything went in perfect. I cant believe how much quieter the truck is, road noise greatly reduced.
RE: tips and tricks;
I cleaned off ALL the old adhesive from around the outter door lip. Time spent on prep work is well spent.
I used laquer thinner, and small patches of scuff pads, rags and something to chip off big chunks of old adhesive -- got it all clean.
Small spring clamps that can be had cheap at home depot, I dry-fitted the seal to see where I wanted the butt joint to lay across the bottom. and marked the seal at the top with a piece of tape, to know where to start when glueing.
I used the small glue brushes to spread the glue (have a little can of laquer thinner handy that you can clean off the brush after each stretch of glueing), and glue up a couple feet at a time.
Like in painting, work clean or the glue can go everywhere with the stringy stuff.
Then I just spread on the glue kinda thick, (use the glue brush to keep it from dripping all over the place), let it tack up for a bit and put on the seal, try not to get the glue all over the seal. I just applied glue to the OUTTER side of the lip. First stretch I glued across the top and the two radiused corners. Used the clamps to keep it where I wanted it. It will dry pretty fast. Then down each side, alternating, The bottom, cutting to fit the butt joint at the bottom.
Later I might add some adhesive to the inner side of the door lip, but Im not sure it is even necessary. I used almost the whole tube of 3M Super Weather Strip Adhesive. Applied the glue rather liberally. Applied the seal on soon enough to spread some of the glue onto the rubber so you will get that contact adhesive going.
Take your time as has been said.
