Since the weather outside windy and the temps are single digit, I figured I would get inside and get work done on the highboy....
It's been a busy day...
Replaced the upper bearing in the column, was gonna do the lower but NPD lists the wrong part...
Replaced the turn signal switch,
Installed dome light brackets and plunger switches...
rewired the Clearance lights:
lnstalled a Circuit breaker (CB)
Installed a relay (87)
Energized the relay from the marker lights and fed via the CB
Fixed the grounds on the clearance lights
Installed new floor dimmer switch
Found a bad horn relay (gotta hit the parts store)
Took out the old dash speaker, gonna replace it, putting in a stock AM radio Monday (if UPS shows up).
Tomorrow is to pull the grill, build and install a new headlight harness (with relays) and new upper headlight adjusters..
Has been / gonna be a productive weekend!
Hope the weekend goes well for the rest of you!
Eric
Weekend work... finally something accomplished..
- 71PA_Highboy
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 F250 4x4 (71) - OB - 360, NP435, D24, HPD60 4.10, D60,
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- Blue Cloud
re: Weekend work... finally something accomplished..
Man, I need a shop!
- ratfink
Hopefully tomorrow, I had to go into my "real" job today.
Feels good to get some stuff done doesn't it.
Ratfink
Ratfink
Dennis
1968 F100 Ranger 390/ C6 (Mine again)
2008 Toyota FJ Cruiser Sandstorm
2007 3500 4X4 Dodge Cummins
Idleness is the mother of all vices.
- 69rangerman
Dang Hiboy! I'm proud if I get the oil changed!
Can't wait til I have the knowledge and skills to move through a list like that! Must feel great!
"O say, does that star spangled banner yet wave? Oer the land of the free and the home of the brave?" It does at my house! God bless America!
- cjs_72f250
it took me a few hours just to yank off the dash pad today.
'72 F250 Explorer Camper Special
- 71PA_Highboy
Wow... am I glad I did the headlight harness today. Once I got in there I found the ground to the voltage regulator was broken off, then just wrapped around the mounting bolt... and the other mounting bolt was gone...
The when I went to write the wiring colors out, the ground on the passengers headlight socket just fell off... I am surprised it even worked..,
Anyway, all the grounds are fixed, the relays are in and it all works great.
Hope everyone else was able to get stuff done too!
Eric
Eric
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- Big D's 69
Looks like a very productive day working on the Bump.
1969 Ford F-100. 302 4 barrel, C4 auto, 9in 3.50 open rear, headers, power steering, Turq/wht, Under restoration. In other words, in a million pieces!!!
There is no Replacement for Displacment!!!
My Photo Gallery: http://www.fordification.com/galleries/ ... ?album=655
