Duraspark wiring question?
- Redcap
When running the hot line (red wire) into the box, I need to run it from something 12v in run/start if I am correct. Where is the proper/best place to tap for power? Anywhere? Solenoid?
- Clarko
- splavin90
re: Duraspark wiring question?
yes.
spice the green/red wire, so that it goes to the coil and the ignition box.
-Sean
-Sean
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
- bluef250
See diagram. I went to the ignition switch and spliced a new wire to the red-green stripe wire. Then attached ignition wire and module red wire on ballast register in engine component.
- Redcap
Oh.
Man, I feel retarded.
Thanks guys.
Thanks guys.
